Are there any pickup rings that fit filtertrons perfectly?
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=54677
Author:  qualendi [ Sat Jan 08, 2022 9:32 am ]
Post subject:  Are there any pickup rings that fit filtertrons perfectly?
Hi, I'm about to buy the classic filtertron pickups from mojotone. After looking at the diagram, it seeams like they are too large to fit regular pickup rings. I'm building a hollow body so there's nothing solid for the pickups to mount onto directly. I'm buying the pickups from Sweetwater so if anyone can direct me to a perfect match from there, that'd be very helpful. It there aren't any, I guess I have to built my own rings.
Author:  Hesh [ Sat Jan 08, 2022 12:58 pm ]
Post subject:  Re: Are there any pickup rings that fit filtertrons perfectl
I would be asking the people who pedal the pups this is not a very active electric guitar forum. Ask Fred at Mojotone or Sweetwater if they sell the stuff they really should know what rings work.
Author:  Barry Daniels [ Sat Jan 08, 2022 2:00 pm ]
You should be able to get a standard humbucker set and trim them to fit.
Author:  Terence Kennedy [ Sat Jan 08, 2022 5:11 pm ]
StewMac has them. If there is a significant contour to your top you may have to make your own.
https://www.stewmac.com/parts-and-hardw ... ting-ring/
Author:  Woodie G [ Sun Jan 09, 2022 8:32 am ]
Good advice - Mojotone was in an all-out sprint to catch up on back orders last time I checked, but they were still picking up the phone...luxury service in our new viral reality.
The shop where I worked used a woodworking-style wheel marking gauge to scribe the plastic parallel to the outside edges of the ring and a radius template (the plastic drafting tool works, as well as a machinist's steel template) to accurately move the corner radius out to the new line. A razor-blade scraper and a fine-toothed round file did the job, with some very low rpm polishing on the freshly worked edges of the plastic with a felt polishing bit loaded with some medium Menzerna or suitable plastic polishing compound.
